15 years agoDDR and DDR2 as a main memory
Hi folks. I am in troubles now. In my system i have two(2) boards. First(with Cyclone III) has a DDR memory and i need it to use as a main memory for NIOS core. The second one(with Aria GX II) ...
15 years ago --- Quote Start --- What error messages are you getting, what are you trying exactly, does something hang or error out or get a warning? --- Quote End --- On both of boards i do not get any message.I mean i can not start debug. Message, i get when i am trying to start is: using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused --- Quote Start --- Where are your reset and exception vectors pointed to? --- Quote End --- Now Reset vector and exception vector are pointing to DDR memory. Now i do not have in my design(temporary) EPCS memory. --- Quote Start --- Does you system come out of reset? --- Quote End --- Yes --- Quote Start --- Do you have valid clocks everywhere they are used? --- Quote End --- I am pretty sure, that YES. --- Quote Start --- Does the DDR pass calibration? --- Quote End --- I do not know. What is this DDR calibration and how to perform it, if i need/must? --- Quote Start --- Have these boards been tested or worked with other designs, just not with your current design? --- Quote End --- One of the boards(the board whit DDR and not with DDR2) is working with other design, and the second one - i didn't see him working. --- Quote Start --- Have you tried to run a simple hello world program running from ddr? --- Quote End --- For design with DDR I am trying simple "Hello word" application ONLY and it does not work. --- Quote Start --- Have you tried to run a simple hello world program with a nios system not connected to ddr just to verify you have working knowlege of the nios ide and that your board generally works? --- Quote End --- One of the boards(the board whit DDR and not with DDR2) it is working great, but for second one ,as i said before - i didn't see him working. Thank you,Kevin. Slava.
