17 years agoDCFIFO and DMA for transfering data to an SRAM
Hi, I have a dcfifo in my design (wich is interfacing two different clocks domains...)... I want to copy the FIFO (not in SOPC) content on an SRAM memory using the DMA (from SOPC). Does any...
17 years agoHello,
I'm having a problem in the compilation when the RX FIFO depth and TX FIFO depth are different. It seems that there is a bug when generating the VHDL code: If TX FIFO depth is 8 bytes and RX FIFO depth is 16 bytes: Error (10344): VHDL expression error at slot1_uart.vhd(1562): expression has 4 elements, but must have 3 elements If TX FIFO depth is 8 bytes and RX FIFO depth is 32 bytes: Error (10344): VHDL expression error at slot1_uart.vhd(1562): expression has 5 elements, but must have 3 elements And so on.. If the two depths are the same, no error occurs. Is there anyone experiencing the same problem? Thank you.
