11 years agoData Transfer from FPGA to HPS Via FPGA connected SDRAM (DE1-SoC)
I have not written code to do this yet, but I thought I would describe my plan here in the hope that any experts present might give me a heads up on any possible problems. I have a NIOS gatheri...
11 years agoThis should be handled by the memory controller which should arbit the ports to it to enforce the correct functionality...
So from the view of the NIOS a read/write is atomic. If you have a bursting Core with e.g. a 128-bit Avalon-MM Interface with 32 bursts and the controller is able to handle that, than a burst of 32 128-bit words should be seen as atomic... And the 16-bit Interface is "only" the physical view of the RAM-Interface...
