12 years agoData Exchange between FPGA and NIOS2
Hi Everyone, I want to implement data exchange between NIOS2 and FPGA . For exampe, transfer data form NIOS2 to FPGA with a Dual Port RAM. Is it possible to do that ? and how to make that happe...
12 years agoHi wangyue2725,
did you solve it? I am working on the same topic. I set up a dual port ram block in qsys with the 2nd slave port exported. i wanted to connect this port to a vhdl module. For testing i connected the address and readdata lines. Since a read happens every clock cycle without explicitly enable; i thought i could write in C directly to the baseaddress of the dpram and directly read this value from my custom vhdl module. in order to do so i assigned from the vhdl module the baseaddress to the dpram and read the value, hoping at one point i would see the value written from the c program. But this approach does not work. Could you help me with this issue or tell me how you connected your component to the second slave port ? Cheers Tim
