10 years agoCyclone V SPI master releases chip select when TX FIFO runs empty. HOW TO PREVENT???
Hi, I have noticed that the Cyclone V SPI master releases chip select when TX FIFO runs empty. I use Linux kernel 4.1, but the spi-dw driver is pretty much the same as in the latest kernel. ...
10 years agoThat is a nice workaround you have there :) Do you need to change anything in the driver to achieve this?
