10 years agoCyclone V Linux - Ethernet (TCP/IP) - Question
Hey guys! :) I've been really confused recently since I got the DE0-SoC board :P (I've worked with Nios and some Texas Instruments DSPs, but never with Linux). In the project I'm developi...
9 years agoHi,
I wanted to know if you were able to implement it. I am just getting started and need to do something similar to you. If possible can you share some tips or anything on how you approached the problem? Maybe even the script you use to send files to PC, how do you establish the connection. Did you make the PC a static IP address?
