11 years agoCyclone V Baremetal application: Could not Determine Target State
Hi, I have a built a system using Qsys and loaded the compiled system into the FPGA. On the software side, I'm able to run the example hello world program on the DS-5. I built an applica...
11 years agoI tried running the Altera example project of altera-socfpga-hardwarelib-fpga-cv-gnu. This same issue repeats for the example project as well. The console messages are as shown:
Connected to running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost source /v "D:\Altera\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check.py" No SYSID registers could be found. Has a peripheral description file been supplied? cd "C:\Users\Administrator\Documents\DS-5 Workspace\Altera-SoCFPGA-HardwareLib-Timer-CV-GNU" Working directory "C:\Users\Administrator\Documents\DS-5 Workspace\Altera-SoCFPGA-HardwareLib-Timer-CV-GNU" source /v "C:\Users\Administrator\Documents\DS-5 Workspace\Altera-SoCFPGA-HardwareLib-Timer-CV-GNU\debug-hosted.ds" +reset system Execution stopped due to a breakpoint or watchpoint: S:0x00000000 S:0x00000000 LDR pc,[pc,#24] ; [0x20] = 0xA8 +wait 30s +stop WARNING(CMD315): Target is not running +wait 30s +set semihosting enabled false +loadfile "$sdir/u-boot-spl.axf" 0x0 Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF6AA3 (size 0x6AA4) Loaded section .rodata: S:0xFFFF6AA4 ~ S:0xFFFF866D (size 0x1BCA) Loaded section .data: S:0xFFFF8670 ~ S:0xFFFF9543 (size 0xED4) Entry point S:0xFFFF0000 Target has been reset Execution stopped due to a breakpoint or watchpoint: S:0x00000000 S:0x00000000 LDR pc,[pc,#24] ; [0x20] = 0xA8 +set semihosting enabled true Semihosting server socket created at port 8000 +delete All user breakpoints deleted +tbreak spl_boot_device Breakpoint 1 at S:0xFFFF13B8 on file spl.c, line 71 on file spl.c, line 81 +run Reloading program Starting target with image C:\Users\Administrator\Documents\DS-5 Workspace\Altera-SoCFPGA-HardwareLib-Timer-CV-GNU\u-boot-spl.axf Running from entry point +wait The program would get stuck after this wait statement. Please advise if I have missed anything. Thanks and Regards, Nitin.
