13 years agoCyclone IV GX Transceiver Starter Kit nterface with ADC module
I wonder who has done a project that interface the Cyclone IV GX transceiver starter kit with an ADC module. I need an ADC module having sampling frequency up to at least 20Mhz. What should I conside...
13 years ago --- Quote Start --- Wow, to use Cyclone IV as a 1-bit ADC sounds very cool. What should I care about using this method? The voltage level connected to SMA connector, LVDS or something else? Your advice is right. I should involve some simulation before the hardware stage. --- Quote End --- So long as you do not violate the input voltage range of the transceiver, its no problem. You can also use an external 1-bit comparator. Hittite, InPhi, and others have parts. To synchronously sample at 1-bit, you need to force the transceiver to stay in lock-to-reference mode. You can also use a couple of comparators and create a 2-bit/3-level ADC. The downside of the 1-bit ADC is that you lose amplitude/power information, since you are essentially detecting just the zero crossings. However, you can recover that with an external power measurement. A 1-bit ADC is not necessarily appropriate for your application - so don't set your heart on it just yet - the key is to design your system before diving into hardware. Cheers, Dave
