19 years agoCyclone - Fitting M4K blocks
I've been experimenting with using different cache sizes in the NIOS CPU. There are sizes which don't compile under Quartus, for instance: Total Logic Elements - 5452 / 5980 (91%...
19 years agoBy changing the data cache line size to 16, I could change the data cache size to 2KB:
; Total logic elements; 5,641 / 5,980 ( 94 % ) ;
; Total memory bits ; 65,024 / 92,160 ( 71 % ) ;
; M4Ks ; 20 / 20 ( 100 % ) ;
; Implementation Port B Depth; Implementatin Port B Width; Implementatin Bits;M4Ks; MIF ;
; 256 ; 2 ; 512 ; 1 ; cpu_0_bht_ram.mif ;
(data cache)
; 512 ; 32 ; 16384 ; 4 ; None ;
; 128 ; 21 ; 2688 ; 1 ; cpu_0_dc_tag_ram.mif ;
; 4 ; 32 ; 128 ; 1; None ;
(instruction cache)
; 1024 ; 32 ; 32768 ; 8 ; None ;
; 128 ; 18 ; 2304 ; 1 ; cpu_0_ic_tag_ram.mif ;
; 256 ; 32 ; 8192 ; 2 ; cpu_0_ociram_default_contents.mif;
; 32 ; 32 ; 1024 ; 1 ; cpu_0_rf_ram_a.mif ;
; 32 ; 32 ; 1024 ; 1 ; cpu_0_rf_ram_b.mif ;
+---------------------------+---------------------------+-------------------+----+---------------------------------+ A "dc_victim_module" has appeared in this one (using 128 bits). What's that?
