13 years agoCustom Linker Script
Dear all,
I have to add an output section in the final binary called "EXTSec". Therefore, I modified the makefile to point to a linkerscript.lds. Then I copied the original likerscript.x contents, which is located in ./bsp folder, and pasted it into my linkerscript.lds. After that, I added the following output section .EXTsec : { ./obj/CRT1.o } > SDRAM As a result, I got the following error ./obj/CRT1.o: In function `Task_CRT1': multiple definition of `Task_CRT1' obj/CRT1.o CRT1.c:19: first defined here collect2: ld returned 1 exit status make: ***[App.elf] Error 1 I need to put all input sections in that object file at the same output section contiguously.
