12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
11 years agoHey Omen,
I am not using any bridges in any of my designs. I have a few simple ones that I've checked this issue out and I've seen it across all of them. As for the hierarchy I'm not sure exactly what you mean. I have a nios cpu with a custom peripheral attached to it in qsys. For example, I wrote an I2C ip core. The core works fine, but when I generate a new bsp it resets the interrupt defines discussed above to -1. I just connect the peripheral to clock, master data line and some output conduits. I attached some pics so you can see...maybe I do have a hierarchy concern and just don't realize it. Qsys screen: http://www.alteraforum.com/forum/attachment.php?attachmentid=9514&stc=1 System.h file: http://www.alteraforum.com/forum/attachment.php?attachmentid=9515&stc=1 Quartus entities: http://www.alteraforum.com/forum/attachment.php?attachmentid=9516&stc=1 One thing I actually just noticed is that my interrupt line (shown in the pic where the# 2 is) is line up with my clk signal and for all of Altera's stuff it is lined up with the MM port.
