16 years agoCustom Instruction addition
Dear all For making the New component for custom instruction addition to Nios processor Five tabs are to be completed new system component, 1)introduction, 2)hdl files, 3)sig...
16 years agoHi
The code is direct as i just took the template of Multicycle logic code given in quartusII installation directory and added a simple direct logic to it // Verilog Custom Instruction Template File for Multi-cycle Logic module custominstruction( clk, // CPU system clock (always required) reset, // CPU master asynchronous active high reset (always required) clk_en, // Clock-qualifier (always required) start, // Active high signal used to specify that inputs are valid (always required) done, // Active high signal used to notify the CPU that result is valid (required for variable multi-cycle) dataa, // Operand A (always required) datab, // Operand B (optional) result // result (always required) ); //INPUTS input clk; input reset; input clk_en; input start; input [31:0] dataa; input [31:0] datab; //OUTPUTS output done; output [31:0] result; reg [31:0] temp; reg[31:0] result; // custom instruction logic (note: external interfaces can be used as well) always@(posedge clk,posedge reset) begin if(reset) result <= 32'b0; else if(clk_en) begin if(start) temp <= dataa+datab; else if(done) result <= temp; end end endmodule regards M Kalyansrinivas
