APaga1
6 years agoCritical Warning (332012): Synopsys Design Constraints File file not found: 'niosii_ethernet_standard_5CGTFD9E.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints.
Critical Warning (332012): Synopsys Design Constraints File file not found: 'niosii_ethernet_standard_5CGTFD9E.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get prope...
SyafieqS
6 years agoHi Avinash,
I have seen and downloaded the design file. Checked the file turn out there is no niosii_ethernet_standard_5CGTFD9E.sdc in the cvgt_simple_socket_server_project directory on my side. Can you verify it from your side and let me know.
APaga1
6 years agoHi Syaf,
Even I couldn't find the niosii_ethernet_standard_5CGTFD9E.sdc in the cvgt_simple_socket_server_project directory. I'm unable to perform timing analysis due to this. So I have chosen this forum to get some help.
