15 years agoCreating sof with NIOS code embedded
So, as title suggests, I have a NIOS system generated with SOPC and NIOS runs from Onchipmem RAM with memory init file my_fpga.hex. I generate the SOPC system. I build the NIOS code which g...
15 years agoMakes sense.
I just realized I had a bridge between NIOS and onchipmem. The mem is at 0x0 but the bridge is at [drum roll] 0x11000000. Long time since I worked on this. :oops: Like to know how you pulled the address 0x11000000 out of the elf. I will get that fixed. Lastly, is there a way to not have to build the whole FPGA whenever we just want to add different elf/hex NIOS code to the sof/jic? Thanks! Cos
