15 years agoCreating sof with NIOS code embedded
So, as title suggests, I have a NIOS system generated with SOPC and NIOS runs from Onchipmem RAM with memory init file my_fpga.hex. I generate the SOPC system. I build the NIOS code which g...
15 years agoSo, done a bit more debugging with no success.
I have included the onchip mem instantiation info from Quartus below. I have verified that the FPGA does in fact boot from the given .jic from power up as I can come in with Eclipse after and download and run the .elf code. So, problem must just be in the NIOS loading/running with the .sof/.jic used. I have fixed this: elf2hex my_fpga.elf --width=32 --base=0x0 --end=0x31FFF ../../my_fpga.hex Not sure if I am calling this correctly. There are a bunch of other options/flags for elf2hex. I am attaching the elf and output hex files. Does the hex look somewhat correct? I noticed all the bytes are pushed to the right side far column with 0x00's everywhere else. I have no idea how to debug this black box and could use a hand. Thx, Cos Info: Instantiated megafunction "my_fpga:my_fpga_inst|onchip_memory2_0:the_onchip_memory2_0|altsyncram:the_altsyncram" with the following parameter: Info: Parameter "byte_size" = "8" Info: Parameter "init_file" = "my_fpga.hex" Info: Parameter "lpm_type" = "altsyncram" Info: Parameter "maximum_depth" = "51200" Info: Parameter "numwords_a" = "51200" Info: Parameter "operation_mode" = "SINGLE_PORT" Info: Parameter "outdata_reg_a" = "UNREGISTERED" Info: Parameter "ram_block_type" = "AUTO" Info: Parameter "read_during_write_mode_mixed_ports" = "DONT_CARE" Info: Parameter "width_a" = "32" Info: Parameter "width_byteena_a" = "4" Info: Parameter "widthad_a" = "16"
