Create a timer
hello to everybody
i'm writing a custom logic , exactly a timer delayed
In sopc builder i add my component , read ports , generate without problems.
After that in quartus II update my system , assign pins , compilation successfull ect .
In Nios II ide i choose my system , build project and seen in system.h my system
and also my component added .I write macro and define my registers to write and read my timer delayed .
In the control register i set the first bit when i need to start my timer , and
i read in status register the first bit to know when my timer expired .
Up to now everythings are ok but it's possible that in vhdl file where i describe my timer , something run no good .
I post my code vhdl
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
entity Timer_Ton is
port (
clk : in std_logic; -- avalon bus signal
reset : in std_logic; -- avalon bus signal
address : in std_logic_vector(1 downto 0); -- avalon bus signal
writedata : in std_logic_vector(31 downto 0); -- avalon bus signal
readdata : out std_logic_vector(31 downto 0); -- avalon bus signal
chipselect : in std_logic; -- avalon bus signal
write : in std_logic; -- avalon bus signal
read : in std_logic; -- avalon bus signal
waitrequest : out std_logic -- avalon bus signal
end;
architecture a of Timer_Ton is
signal busy : std_logic;
signal start: std_logic;
signal timer_done:std_logic;
signal mem: std_logic;
signal mem2: std_logic;
signal ok_count_timer:std_logic;
signal reg0w : std_logic_vector(31 downto 0); -- control register
signal reg0r : std_logic_vector(31 downto 0); -- status register
signal reg1w : std_logic_vector(31 downto 0); -- preset register
signal ms_counter:unsigned(31 downto 0);
signal preset:integer range 0 to 10800000;
signal counter_clock : unsigned(31 downto 0);
begin
process(clk,reset)
begin
if(reset='1' then
busy<='0';
waitrequest<='1';
readdata <= (others =>'0'
reg0w<=(others =>'0'
reg0r<=(others =>'0'
reg1w<=(others =>'0'
else if(rising_edge(clk)) then
if(chipselect='1' and busy='0' then
busy<='1';
case address is
-- CONTROL REGISTER ADDRESS=0x00
when "00" =>
if(write='1' then
reg0w <= writedata;
else if(read='1' then
readdata <= reg0r;
end if;
end if;
waitrequest <='0';
-- CONTROL REGISTER ADDRESS=0x01
when "01" =>
if(write='1' then
reg1w <= writedata;
readdata <= reg1w;
end if;
end if;
waitrequest <='0';
when "10" =>
if(write='1' then
--reg2w <= writedata;
else
if(read='1' then
--readdata <= reg2w;
end if;
end if;
waitrequest <='0';
when "11" =>
if(read='1' then
-- readdata <= reg3r;
end if;
waitrequest <='0';
when others => null;
end case;
end if; -- STB
if(chipselect='0' then
busy<='0';
waitrequest<='1';
end if;
end if; -- CLK
end if; -- RST_i
start<=reg0w(0);
reg0r(0)<=timer_done;
end process;
clockrocess(clk,start)
begin
if(start='0' then
ms_counter<= "00000000000000000000000000000000";
counter_clock<="00000000000000000000000000000000";
mem<='0';
ok_count_timer<='1';
timer_done<='0';
elsif(rising_edge(clk)) then
if(counter_clock=150) then
ok_count_timer<=not ok_count_timer;
else
counter_clock<=counter_clock+1;
end if;
if(ok_count_timer='1' then
if(ms_counter=unsigned(reg1w) ) then
timer_done<='1';
else
ms_counter<=ms_counter+1;
timer_done<='0';
end if;
end if;
end if;
end process;
end a;
i use system clock (50 Mhz) and i try to divide it , after i increment accumulator
of my timer and when is equal than register preset i set timer_done .
timer_done i copy in first bit of status register .
But after all i cannot understand how to have a clock every 100ms (for example)
Here i post Nios II .C file
#include "count_binary.h"
sDato count;
sDato mem;
sDato val;
#define out val.B.B7
#define puls count.B.B5
#define fc count.B.B6
// REGISTER
#define CONTROL_REGISTER 0
#define STATUS_REGISTER 0
#define PRESET 1
#define ACTUAL_TIME_REGISTER 2
static void count_led()
IOWR_ALTERA_AVALON_PIO_DATA(PM_OUT_BASE, count.W);
//funzione che scrive gli Output
static void Write_Output()
IOWR_ALTERA_AVALON_PIO_DATA(PM_OUT_BASE, val.W);
//funzione per scrivere gli 8 led pizzamicro
static void out_led()
#ifdef PM_OUT_BASE
#endif
int main(void)
int i;
IOWR(TON_0_BASE,CONTROL_REGISTER,0);
while( 1 )
if(count.B.B7)
IOWR(TON_0_BASE,PRESET,12000000);
IOWR(TON_0_BASE,CONTROL_REGISTER,1);
else
IOWR(TON_0_BASE,PRESET,0);
count.W=IORD_ALTERA_AVALON_PIO_DATA(PM_IN_BASE) ;
if((count.B.B0) & (!mem.B.B0))
val.W++;
mem.B.B0=1;
if(val.W>255){val.W=0;}
if(!count.B.B0)
mem.B.B0=0;
// val.B.B7=(count.B.B5 | val.B.B7) & !count.B.B6;
out=(puls | out) & ! fc;
i=IORD(TON_0_BASE,STATUS_REGISTER);
val.B.B6=i & 0x01;
Write_Output();
return(0);
I would like to know how to generate a 100ms clock to use in my timer
for incrementing accumulator register
thanks to eveybody
walter
