12 years agoCount_Binary alt_u8 not found
I have a simple NIOS II/s running the count_binary example. Eclipse is used as installed by Altera. The problem I'm running into is if you start a new project and select count_binary everything is fi...
10 years agoI just ran into this same disturbing issue in my own code, and I was able to resolve it timely by adding to the C++ and C library paths per swimteam's instructions.
Thank you for taking the time to share! Cheers --todd
