12 years agoCount_Binary alt_u8 not found
I have a simple NIOS II/s running the count_binary example. Eclipse is used as installed by Altera. The problem I'm running into is if you start a new project and select count_binary everything is fi...
12 years agoswimteam:
I also just fell into the same hole that you described: yesterday, I successfully worked thru the count_binary sample, shut down, etc., only to find today that alt_u8, null, and file could not be resolved once I re-opened the project this morning. I experimented with your steps, then ended up adding the three include paths from the software/count_binary base directory to the count_binary_bsp includes Paths and Symbols. As you discovered, and I just confirmed, stddef.h had to be manually added to count_binary.h. I used Eclipse before (about 4 years ago), but this really seems convolved - even for Eclipse. Engineer Scott's famous statement came to mind: "the more they overthink the plumbing, the easier it is to stop up the drain." Thanks much for your post and solution. Thanks! Dave
