12 years agoCount_Binary alt_u8 not found
I have a simple NIOS II/s running the count_binary example. Eclipse is used as installed by Altera. The problem I'm running into is if you start a new project and select count_binary everything is fi...
12 years agoswimteam,
Are you referring to C/C++ Indexing errors (specific to the Eclipse IDE/CDT -- CODAN, code analysis) or are you actually seeing build (GCC toolchain/make) errors? The former should be transitory and can usually be ignored. The latter....well, it depends. :-)
