13 years ago
Copying projects to another PC. BSP has absolute paths
I'm trying to get a handle on how to clone my project and make it build on another PC.
But I see that my NIOS BSP uses absolute paths to access the sopc info file. Simply changing the filename in the make file wouldn't work
How do I copy a complete project along with its NIOS projects and make sure it works in another system?
Zubair
p.s. using Quartus 12 + NIOS SBT 12..
    You can fix the absolute path to the .sopcinfo file by manually editing the XML file (settings.bsp). You are looking for the "<SopcDesignFile>" element, about 10 lines down from the top. Just change it to be a relative path.
    The settings.bsp is the only file you actually need to copy as far as BSP files; then on each fresh PC you need to "generate" the BSP again.
    Changing makefile and settings.bsp both worked.
    Thanks!
    Zubair
    --- Quote Start ---
    Thanks!
    Zubair
    --- Quote End ---
    There is another good way to solve this problem.
    First regenerate bsp.
    Then in application project Index -> rebuild.
    Then build project.
    And then run this on hardware.
    Re-indexing detects the relative current paths of the files related to the project.
    Similar is the case when you regenerate your new/modified Qsys system. Same procedure.
