13 years agoCopying projects to another PC. BSP has absolute paths
Hi, I'm trying to get a handle on how to clone my project and make it build on another PC. But I see that my NIOS BSP uses absolute paths to access the sopc info file. Simply changing the...
13 years agoYou can fix the absolute path to the .sopcinfo file by manually editing the XML file (settings.bsp). You are looking for the "<SopcDesignFile>" element, about 10 lines down from the top. Just change it to be a relative path.
The settings.bsp is the only file you actually need to copy as far as BSP files; then on each fresh PC you need to "generate" the BSP again.
