20 years agoCopy user-file from EPCS4 to SDRAM
I boot both configuration and NIOS software from a EPCS4. Works fine, the flash programmer is doing a great job. I also define a character set (pixel map) that resides in the 8th (and upper) 64K bloc...
15 years agoDear AlexS,
Please update me with the procedure how to store my own data on epcs device, I am using Cyclone II 2c20 device with epcs4 in active serial configuration, and a SRAM for NIOS II, I want to store sof file, NIOS II code (which is already tested) with my own data. If you have some sample code please update me with the same. Thanks.
