20 years agoCopy user-file from EPCS4 to SDRAM
I boot both configuration and NIOS software from a EPCS4. Works fine, the flash programmer is doing a great job. I also define a character set (pixel map) that resides in the 8th (and upper) 64K bloc...
20 years agoIf I clear understand you try to read/write to EPCS using your own program after booting.
If yes, i can explain how to do it in details.
