10 years agoControlling HPS pins from FPGA using Cyclone 5
Hi, I am trying to blink a LED which is connected to the HPS from a button connected on the FPGA. I have built the Qsys design and Loaned the I/O desired pins to the top level entity, then by s...
10 years agoHi, do you update the preloader on the device? Note that the Pin Mux for the IO is located within the HPS - as such you will need to update the preloader once you set a Loan I/O to the HPS.
