16 years ago
Console on framebuffer (NEEK)
Hi Any!
With version nios2-linux-20090929.tar with stable kernel,
I would like to display console to LCD.
Also would like to run the program with PS2 connection keyboard.
I tried with refferring to the following URL, but it have stoped during bootup.
nioswiki.com/OperatingSystems/UClinux/FrameBuffer
alteraforum.com/forum/showthread.php?t=22497
(please add part of URL)
>Linux/Nios II-MMU
>init_bootmem_node(?,0x516, 0x0, 0x2000)
>free_bootmem(0x516000, 0x1aea000)
>reserve_bootmem(0x516000, 0x400)
>Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
>Kernel command line:
>Experimental hierarchical RCU implementation.
>Experimental hierarchical RCU init done.
>NR_IRQS:32
>PID hash table entries: 128 (order: 7, 512 bytes)
>Console: colour dummy device 80x25
>console handover: boot [early0] -> real [tty0]
The following config options seem to happen.
Device Drivers --> Character devices --->
[* ] Support for console on virtual terminal
Someone please advice...
Thank you.
    dmseg the "fb0: altfb frame buffer device" message has come out.
    fb0 seems to have been confirmed.
    After booting the kernel and run the application.
    /Dev/fb0 has open, mmap() call...
    Kernel Panic occurred here.
    >> /app/lcd_test# ./lcd_test
    >> The framebuffer device was opened successfully.BUG: failure at /usr/sira/nio
    >> s2-linux/linux-2.6/mm/mmap.c:2121/exit_mmap()!
    >> Kernel panic - not syncing: BUG!
    >> IMG_X_SIZE defined 20
    >> IMG_Y_SIZE defined 10
    >> xres is 21
    >> yres is 11
    >> bytes per pixel is 4
    >> screensize is 693
    >> finfo.smem_len is 1536000
    >> Error: failed to map framebuffer device to memory.
    Which version are you do you run Framebuffer?
    Please tell me the clue to this problem.
    I appreciate if you help me.
    Sorry, lacked information.
    Remove the option, first trying to determine just FrameBuffer are working.
    best regards.
