15 years agoConnecting an RSA-Coprocessor to a NiosII System
Hi, I designed a rsa coprocessor in Verilog which has to take inputs and put outputs directly into Memory (since arguments are quite large, about 5 or 6 and 1024 bit each). So I made the Coprocessor ...
15 years agoI still don't get it... Is your main processor inside or outside your SOPC system? If it's outside, you'll have problems sharing the SDRAM between the processor and coprocessor.
