15 years agoConnecting an RSA-Coprocessor to a NiosII System
Hi, I designed a rsa coprocessor in Verilog which has to take inputs and put outputs directly into Memory (since arguments are quite large, about 5 or 6 and 1024 bit each). So I made the Coprocessor ...
15 years agoDo you connect to a processor outside of the SOPC builder project or FPGA? In that case yes you should use a conduit interface and you can use whatever signals you want. The other interfaces can only be used inside SOPC builder AFAIK (with the exception of the tristate MM, but I don't think it will help you in this case).
