10 years agoConnecting 2nd Jtag2AVM to f2h_axi_slave causes system console to hang up
Hi, I'm trying to create my first HPS system on a C5 Soc board from Terasic. If I create a system with one JTAG2AVM bridge (called fpga_console in picture qsys_causing_no_error.png) I can run...
10 years agoMy friend solved the other two problems.
She did redo everything I did. She started from scratch and did do only what the manual said. Apparently I did something wrong (still haven't found what) The other thing I would like to mention, is that the f2h_axi_slave doesn't work, when the HPS is not loaded with a PRELOADER configuration. As soon as that is done, the HPS has clocks and is out of reset. And then you can access the LEDS's and BUTTONS trough the f2h_axi slave interface by the HPS-JTAG2AVM bridge.
