15 years agoConfiguring NIOS processor through AS interface
Hi all, I have been searching all day on a solution to my problem, or to find out if I totally screwed up my first design. I designed my own board with a Cyclone II processor and an EPCS4 ...
15 years agoThanks for trying so far, but the flash programmer is useless without a jtag interface. I have created a .hex file from my NIOS .elf and I found out I can use Quartus's convert menu to combine the sof and hex into a pof which can be programmed. Now I'm working on making the NIOS program do something that will show me if it's running or not, since there is no way to run the program directly from the Nios IDE.
