15 years agoConfiguring NIOS processor through AS interface
Hi all, I have been searching all day on a solution to my problem, or to find out if I totally screwed up my first design. I designed my own board with a Cyclone II processor and an EPCS4 ...
15 years agoI am trying to avoid redesigning and rebuilding my PCB with a jtag header.
The solution I am working on right now is converting my .elf to a .hex and setting this .hex as the non-default initialization file for an onchip ram in SOPC builder. The only other references I have found are using elf2flash and sof2flash but the flash programmer needs a jtag connection as well so I can't program the flash files.
