Configure NIOS firmware burning interface
Thank you for you reply!
1) I know how to add UART to NIOS. my question is: if I add a general/common UART, could I program/burn NIOS firmware(not FPGA bitstream) via the UART? If I would like to program/burn NIOS firmware(not FPGA bitstream), how to configure the UART or how to enable NIOS SDK?
2) is there a way to program/burn NIOS firmware and FPGA bitsteam via JTAG or UART together? how to configure NIOS and how to enable it in SDK? Could you please tell me the detailed steps for JTAG and UART programming/burning and configuring method respectively?
3) I didn't get your explanation about Check Resource Utilization. Could you please explain the detailed steps? and how to calculate the remained FPGA resource and RAM size I can set?
4) Your explanation about Conduit and AXI4Lite is very clear. I got it. Thank you.
5) I installed the software QuartusSetup-18.1.0.625-windows.exe whose size is 2272090KB. I don't know where the EDS is installed together. is there a way the check whether it is installed or no? By the way, I could open Eclipse via Tools--> NIOS II Software Build Tools for Eclipse which is installed for embedded system.
