Configuration of on-chip memory width for dual port access
I am using Quartus 19.1. I would like to use a dual-port RAM to pass data from the fabric to the Nios soft processor.
It is my understanding that the Nios port width must be set to 32 bits, but I would like to write 64 bits at a time from the fabric.
However, the option 'enable different port width for dual port access' is always greyed out, and therefore now available. I have attached a screenshot.
I would like to not have to write 2x 32 bits from the fabric.
How do I enable different port width?
Thank you,
BeB
- EricMunYew_C_Intel
Nios II supports 32 bit data width. Therefore you can't write 64 bit data from the FPGA fabric.
It will take two cycles to write 64 bit data.
