10 years agoCompress and optimize application
I have an application when converted to hex, creates 850 KB file size. I need this application to sit in on-chip memory of 5CEFA5F23C device. The max on-chip memory size which could be assigned is 41...
10 years ago --- Quote Start --- I have an application when converted to hex, creates 850 KB file size. I need this application to sit in on-chip memory of 5CEFA5F23C device. The max on-chip memory size which could be assigned is 412000 Bytes. I need to somehow compress the hex file in order for it to fit in on-chip memory. Can you please suggest a way to do this? I am using NIOS II EDS V14.1 --- Quote End --- You might try one of the LZRW algorithms, I used one several years ago to improve on Altera's compression. Here is a link: http://www.ross.net/compression/
