11 years agoCompiling assembly file to hex file
I am attempting to compile my source.s code into the hex file that will be placed in my system RAM. This must be done completely through the command line and I am having some problems. I am using the...
11 years agoCheck the generated Makefile. Do install cygwin?
How did you generate the Makefile at the first place? Using eclipse or command line? You can try using the Nios II command shell.
