Compiing uC-TCP-IP for NiosV
Hi Intel Forums,
I'm trying to build the simple socket server for an Agilex 7 devkit. I've got the NiosV processer and peripherals set up via platform designer and I've built a BSP with includes the 'uC-TCP-IP' libraries. Unfortunately when I try to build the C project in RiscFree, I get this error:
[ 77%] Building C object bsp/CMakeFiles/hal2_bsp.dir/uC-TCP-IP/uC-LIB/lib_math.c.obj
<MY LOCAL PATH>/software/bsp/uC-TCP-IP/uC-DHCPc/OS/uCOS-II/dhcp-c_os.c:166:9: error: unknown type name 'OS_TMR'
166 | static OS_TMR *DHCPc_OS_TmrPtr;
Is there something I need to include to solve this error?
Let me know if there's more information I can provide. If needed I can share the whole project or the qsys file.
Thank you,
Sam
- tehjingy_Altera
Hi
You would need to edit the BSP settings for the Nios V.
Please follow the steps below:
Jingyang, Teh
- tehjingy_Altera
Hi
Do you have any update on this case?
Are you able to compile the example desing after the BSP configuration?
Jingyang, Teh
- tehjingy_Altera
Hi
Jingyang, Teh
