10 years agoCommunication stop's (ping) after Running DS-5 Debug
Hello Friends, I am learning "write a c/c++ application for altera cyclone v soc dev kit using arm ds-5 ae" and following youtube article https://www.youtube.com/watch?v=iyezox1ywmm p...
10 years ago --- Quote Start --- another thing is could you try this sequence. launch ecipse from shell and connect target first, after that only open up the putty to see the status? --- Quote End --- i am following the same sequence as you mentioned. like 1. Open the embedded Shell 2. Run "Eclipse" from there 3. Trying to Connect the Project (Don't no Without Project can we connect the board or not , but i am going to try it also) regards kaushal
