10 years agoCommunication stop's (ping) after Running DS-5 Debug
Hello Friends, I am learning "write a c/c++ application for altera cyclone v soc dev kit using arm ds-5 ae" and following youtube article https://www.youtube.com/watch?v=iyezox1ywmm p...
10 years ago --- Quote Start --- brother... can you verify all the jumpers on your board first???? usually you may see some suprose fomr there.. --- Quote End --- * attched is the print screen of errors Every thing seems ok, until i reach to run Debugger. prior to that i am able to ping my SoCKit from Windows machine and also able to see the OS status on PuTTY. as soon as i run the Debugger, windows machine lose its Ethernet connectivity i mean Ping stop and no further connectivity. (I have repetitively seen this issue). i have choose SSH Connection in remote system configuration. i am not sure is it SSH related problem or is it arm license related issue (as my compilation goes well, i remove the micro-sd card from board and copy the compiled executable file to microsd card and then run the code --it work). I have't change any jumper setting , or it need some unique jumper setting . below is the board i am using http://rocketboards.org/foswiki/view/Documentation/ArrowSoCKitEvaluationBoard
