17 years agoClock cycles per IORD instruction
Hi, Does anyone know how many clock cycles IORD instruction needs? It looks like 2, but I would like to clarify it. If it is 2, does mm_slave_read stay high for both clock cycles? Thi...
17 years agoHello,
The number of cycles depends on the slave. It could take just 1 cycle if the slave allows it. You can also have a fixed number of wait states, or variable wait states if the slave implements the waitrequest signal. In your case it looks like you have one wait state inserted. In any case, the read signal does remain high throughout the read. The Avalon MM Interface Specification gives timing diagrams for various cases. Cheers
