15 years agoCIII/EPCS design configures and programs but does not start
Hi, I have a design with EP3C40 and EPCS64. I create flash files with: sof2flash --epcs --compress --input=logic.sof --output=logic.srec elf2flash --epcs --after=logic.srec --input=softwar...
15 years agoHi Mark
I do nearly the same with a CIII and it works. Compare my steps to yours, although the differences are (apparently) irrelevant. 1- sof2flash --epcs --input=logic.sof --output=logic.flash 2- elf2flash --epcs --after=logic.flash --input=firmware".elf --output=firmware.flash 3- nios2-configure-sof --cable='USB-Blaster [USB-1]' logic.sof 4- nios2-flash-programmer --cable='USB-Blaster [USB-1]' --epcs --base=0xa00000 logic.flash 5- nios2-flash-programmer --cable='USB-Blaster [USB-1]' --epcs --base=0xa00000 firmware.flash
