10 years agoChange size of Memory
Hi I have a DDR3 Memory with the HMC. I have som important Data (Nios Instruction and Data) and some nonimportant Data (from external). Both process have to write into the RAM. I now realized, ...
10 years agoYou could try use the address span extender to create a window like view into the Avalon interface so that the masters see different base addresses. And you can split the memory to 2 logically.
