10 years agoCFI FLASH Programming by Nios II
Hi, I have a spansion S29GL064N CFI flash that connected to a cyclone IV FPGA and I use Quartus II V11.1. when I use nios2-flash-programmer command in the command shell, CFI flash table found. al...
10 years agoHi,
Thanks. Can i use cfi flash in the active parallel mode , if i connect it to dedicated active parallel fpga pins similar to "AP Configuration" sectiON,of the Configuration and Remote System Upgrades in Cyclone IV Devices. REGARDS
