10 years agoCFI FLASH Programming by Nios II
Hi, I have a spansion S29GL064N CFI flash that connected to a cyclone IV FPGA and I use Quartus II V11.1. when I use nios2-flash-programmer command in the command shell, CFI flash table found. al...
10 years agoIf you were able to verify the content of the flash then the problem is in your pof file. Make sure your FPGA configuration and software work properly when downloaded directly with JTAG. Once that is verified, see the Altera instructions on creating a pof file and try again.
