15 years agoCan't reset PIO edge capture using IOWR_ALTERA_AVALON_PIO_EDGE_CAP
Dear experts, I am Nios beginner. I wonder why I cannot reset the edge capture register using IOWR_ALTERA_AVALON_PIO_EDGE_CAP (to reset it inside my ISR)? //after first interrupt...
11 years agoThat's incredible! The same code with the same error is generated by Nios II SBT for Eclipse in the count_binary sample, that writes:
IOWR_ALTERA_AVALON_PIO_EDGE_CAP (BUTTON_PIO_BASE,0); writting '0' instead '1'... I was one day looking for the error and debugging the program before coming to these fora, when I finally found the solution. Why the sample code is wrong? Additionally, I have problems writting the display with the code generated by the system... I will look again in the forum to see if this is due again to errors in it... Regards, Antonio
