16 years agoCan't open uart in uClinux with MMU
Hi~
Right now, I am using uClinux with MMU. My system have 3 uart, however, My system can't see all uarts. He always show 2. Moreover, in ternimal, it shows I have this device, but I can't open it. http://i37.tinypic.com/ifx405.jpg This picture is my setting about uart http://i36.tinypic.com/244tu0x.jpg Is there any other select I need to change. Do I need to change config.c inside arch/nios2/board folder? Thanks in advance for your help. Tingming5 Replies
Maybe you need /dev/ttyS2, /dev/ttyS3...:D Kazu - Altera_Forum
Hi Kazu:
I don't get it, why I need /dev/ttyS2 and S3? I have 3 uart in my system, but it only show 2. And I can't open (ttyS0 and ttyS1) in software. Thank you very much for reply me. - Altera_Forum
--- Quote Start --- I don't get it, why I need /dev/ttyS2 and S3? I have 3 uart in my system, but it only show 2. And I can't open (ttyS0 and ttyS1) in software. --- Quote End --- Please check that your UART names are well-defined in the file 'nios2-linux/linux-2.6/arch/nios2/kernel/config.c', and if not, please modify it. In default, those must be 'UART0. 'UART1', 'UART2' and 'UART3'.
And UART devices are probed in the function 'altera_uart_probe' of the file 'nios2-linux/linux-2.6/drivers/serial/altuart.c'./* * Altera UART */ static struct altera_uart_platform_uart nios2_uart_platform = {# if defined(UART0_BASE) || defined(UART_BASE) # ifdef UART0_BASE { .mapbase = UART0_BASE, .irq = UART0_IRQ, .uartclk = UART0_FREQ, }, # else { .mapbase = UART_BASE, .irq = UART_IRQ, .uartclk = UART_FREQ, }, # endif# endif# ifdef UART1_BASE { .mapbase = UART1_BASE, .irq = UART1_IRQ, .uartclk = UART1_FREQ, },# endif# ifdef UART2_BASE { .mapbase = UART2_BASE, .irq = UART2_IRQ, .uartclk = UART2_FREQ, },# endif# ifdef UART3_BASE { .mapbase = UART3_BASE, .irq = UART3_IRQ, .uartclk = UART3_FREQ, },# endif {}, };
Please debug it by 'printk', if necessry. Anyway you must distinguish your UART devices by major and minor numbers, so you need /dev/ttyS2 and /dev/ttyS3 after your 4 UARTs are probed successfully. Kazustatic int __devinit altera_uart_probe(struct platform_device *pdev) { struct altera_uart_platform_uart *platp = pdev->dev.platform_data; struct uart_port *port; int i; for (i = 0; ((i < CONFIG_SERIAL_ALTERA_UART_MAXPORTS) && (platp.mapbase)); i++) { port = &altera_uart_ports.port; port->line = i; port->type = PORT_ALTERA_UART; port->mapbase = platp.mapbase; port->membase = ioremap(port->mapbase, ALTERA_UART_SIZE); port->iotype = SERIAL_IO_MEM; port->irq = platp.irq; port->uartclk = platp.uartclk; port->ops = &altera_uart_ops; port->flags = ASYNC_BOOT_AUTOCONF; uart_add_one_port(&altera_uart_driver, port); } return 0; } - Altera_Forum
Hi Kazu~
Thank you very much! My UART (S0 S1)can work already. Now, I am trying to make S2 work. I use mknod /dev/ttyS2 c 4 66, and my ttyS2 can work now I didn't change config.c files, so I can't use my UART. Thank you again for solving my problems. TingMing. - Altera_Forum
Thanks in advance if you can shine light to the UART problem I am having. Like the problem you are having, I can't open the port or communicate to it, and I have name all my port with 'UART0. 'UART1', 'UART2' and 'UART3' in my QSYS and my device tree DTS file. The uClinux ver 3.1 boot up detect there is a UART with correct base address and irq: ttyAL0 at MMIO 0x8100160 (irq =5) is a Altera UART ttyAL1 at MMIO 0x8100180 (irq =6) is a Altera UART ttyAL2 at MMIO 0x8100200 (irq =7) is a Altera UART ttyAL3 at MMIO 0x8100220 (irq =8) is a Altera UART ttyAL4 at MMIO 0x8100240 (irq =9) is a Altera UART ttyAL5 at MMIO 0x8100260 (irq =10) is a Altera UART The /dev have ttyAL0 in it, but not none of the other ports. I'm able to open and communicate with ttyAL0, but none other port. Is there something I have to do specially for the device tree or driver I have to change? I did look at the altera_uart.c and can't figure out the problem. --- Quote Start --- Hi, Please check that your UART names are well-defined in the file 'nios2-linux/linux-2.6/arch/nios2/kernel/config.c', and if not, please modify it. In default, those must be 'UART0. 'UART1', 'UART2' and 'UART3'.
Please debug it by 'printk', if necessry. Anyway you must distinguish your UART devices by major and minor numbers, so you need /dev/ttyS2 and /dev/ttyS3 after your 4 UARTs are probed successfully. Kazu --- Quote End ---static int __devinit altera_uart_probe(struct platform_device *pdev) { struct altera_uart_platform_uart *platp = pdev->dev.platform_data; struct uart_port *port; int i; for (i = 0; ((i < CONFIG_SERIAL_ALTERA_UART_MAXPORTS) && (platp.mapbase)); i++) { port = &altera_uart_ports.port; port->line = i; port->type = PORT_ALTERA_UART; port->mapbase = platp.mapbase; port->membase = ioremap(port->mapbase, ALTERA_UART_SIZE); port->iotype = SERIAL_IO_MEM; port->irq = platp.irq; port->uartclk = platp.uartclk; port->ops = &altera_uart_ops; port->flags = ASYNC_BOOT_AUTOCONF; uart_add_one_port(&altera_uart_driver, port); } return 0; }
