RPind1
6 years agoCan't communicate MT25Q flash over Serial Flash Controller II Intel FPGA IP with quartus_pgm --nios2 or Nios Flash Programmer-- Error 18927 FAILED when using quartus_pgm
I Can't communicate (with Nios Flash Programmer or quartus_pgm) with a flash chip ( MT25QU1G ) on an Arria V via the Serial Flash Controller II on the NIOS processor. (We can however use the chip to ...
RPind1
6 years agoHi Ahmed. I don't see any requirement on a MINIMUM speed. Can you point me to that documentation. I have only ever seen an FMAX published. I used 10Mhz because it was the only available clock I had under FMAX. I can and will adjust to FMAX once working it I have the routing resources
