11 years agoCannot route console output to serial Altera UART when booting kernel from RAM
Hi, I have successfully created images for U-boot and for the Linux kernel 3.10.37-ltsi-rt37 (vmImage) that direct the console output through the Altera UART component. I have also programme...
11 years agoHello Brad,
Although I am not sure whether it would work for you or not, there is one option "-r" which you can try. It is used to reset target system before use. For example, you can try it in following way : "nios2-download <ELF filename> -g -r" Let see what happens at your end. Thanks, Bhaumik
