Cannot find Sopcinfo file for SFP+ interface
Hi
I am using Ubuntu version 20.04.5 system & I have installed the Intel Quartus Prime Pro Edition 20.1 (FREE, no license file required) following the below procedure link.
Also installed the Eclipse IDE into NIOS II EDS from the below procedure link.
https://www.terasic.com.tw/wiki/Getting_Start_Install_Eclipse_IDE_into_Nios_EDS
Then I used the sss_qsys.sopcinfo file to configure the "Target hardware information" for the Cyclone 10 GX Development board following the below method.
Open Nios II Eclipse IDE -> Goto File -> New -> Nios II Application and BSP from Template -> selecting the sopcinfo file( Downloaded from the below link having kit collateral example codes)
https://www.intel.in/content/www/in/en/products/details/fpga/development-kits/cyclone/10-gx.html
Using this sopcinfo file I am able to load the CPU & new project was created. Now I want to test the SFP+ interface in the Cyclone 10 GX development board after integration, but I am not able to find the SFP+ connector interface sopcinfo file in the kit collateral zip file.
Kindly share the integrated sopcinfo file for SFP connector interface.
Anu Jayan
- KellyJialin_Goh
Greetings and welcome to Intel's forum.
Apologies, we do not have the sopcinfo file for SFP + interface. Files that are available in the zip are the ones that are accessible. Sorry for any inconvenience caused and feel free to try out other applications from the zip file or head to Intel's design store with this link:https://fpgacloud.intel.com/devstore/ to try out design examples on Cyclone 10 GX.
Thank you.
Regards.
Kelly
- Anu_Jayan
Thank you for the response. It would be great if you provide sample C codes for testing the SFP + interface through Nios II Eclipse IDE for Intel Cyclone 10 GX development board.
Also can you share any links with the testing procedures for the same.
Thanks & regards
Anu Jayan
- KellyJialin_Goh
Thank you for your swift response.
I have asked the internal engineering team regarding the c code but however we are unbale to release externally due to Private and confidential.
However, I found a design example which utilizes the SFP+interface which is the board test system, BTS that can be found in the zip file you downloaded (in examples directory). Here is the link on BTS info for Cyclone 10 GX: https://www.intel.com/content/www/us/en/docs/programmable/683696/current/the-xcvr-tab.html
Thank you.
Kelly
- KellyJialin_Goh
Any updates from your side? Is there any further help needed from my end?
Thank you.
Kelly
- Anu_Jayan
Thank you for your response. I will get back to you, if I need anything further.
Thanks & Regards
Anu Jayan
- KellyJialin_Goh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Kelly Jialin, GOH
