13 years agocannot create bsp in Eclipse for Quartus 13.0
I just installed Quartus 13.0, and now I cannot create a Board Support Package from within Eclipse (right-click, New->Nios II Board Support Package). I get the error dialog shown below ("Failed to qu...
13 years ago --- Quote Start --- Same problem here on three machines I have installed 13.0 on. I hope someone has the answer. --- Quote End --- I filed a service request and received the following reply: "There is a bug in the GUI for the bsp creation page for Nios II Software Build Tools for Eclipse in ACDS 13.0. The bug is currently planned to be fixed in 13.1. We are sorry for any inconvenience caused due to this bug. As a workaround for this issue, instead of choosing New->Nios II Board Support Package, choose the option New -> Nios II Application and BSP from Template. Select the template Hello World if you would like to have Altera HAL as the Operation System, else select Hello MicroC/OS-II if you would like to include the MicroC/OS-II RTOS. Please note that you should not click "Next", so that you won't be directed to the bsp page which has bug. Click finish after you have filled in the required information. The bsp project created will be automatically named as <application project name you specify>_bsp. You may delete the application project later if it is not needed."
