DrLandman
5 years agoCannot build examble project to run on NIOS II
Article ID: 000073922Content Type: Error MessagesLast Reviewed: 09/16/2019
Error: Failed to execute: wsl ./create-this-app –no-make
This problem still present in Quartus Lite 21.1. In addition, I cannot run Nios Command Shell (your proposed workaround) either. When will the problem be solved ?>
1 Reply
- EBERLAZARE_I_Intel
Are you using windows 10?
Please refer below for the installation required:
