11 years agocan not export the master interface of avalon-mm pipeline bridge
I need to make Qsys export an Avalon-MM Master for configuring a IP core which has a Avalon-MM Slave interface, but I got this error from eclipse while downloading the software: No Nios II target ...
11 years agoExported pipeline bridge will not work from the way you have it connected. Can you connect the IP core within the Qsys system instead of exporting the pipeline bridge?
If you still need exported pipeline bridge, I would suggest you to move the onchip memory to 0x4_0000 from 0x1_0000 currently. Fingers crossed, it should work.
